Author Topic: Can someone help with CP  (Read 1964 times)
Evilpenguin
  • Last login:November 30, 2007, 06:53:35 pm
  • MegaMame
« on: June 22, 2004, 05:12:26 pm »
Hi all
I am really new to vector graphics.  I am going to try to come up with a decent control panel overlay.  I was wondering if someone could come up with a template for me.  I have included a crude pic that shows what it looks like with some basic dimentions.  So if someone could just create that outline with the correct mesaurements I would really appriciate it.
« Last Edit: June 22, 2004, 05:15:34 pm by Evilpenguin »
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
Re:Can someone help with CP
« Reply #1 on: June 22, 2004, 08:57:26 pm »
What program do you want it to be done in?  Adobe Illustrator?
Evilpenguin
  • MegaMame
« Reply #2 on: June 22, 2004, 09:56:58 pm »
Yes I want it in Adobe Illustrator.  .AI format!  Thanks if you can do it.
Jason
TalkingOctopus
    • My Arcade
« Reply #3 on: June 22, 2004, 11:28:11 pm »
Sure, I'd be happy to help, but I don't fully understand your diagram.  What is 5 1/2"?  The diagnol, the height, or the width?
Evilpenguin
  • MegaMame
« Reply #4 on: June 23, 2004, 01:47:43 am »
5 1/2 is the little diagonal piece.  Hope that helps.
Jason
TalkingOctopus
    • My Arcade
« Reply #5 on: June 23, 2004, 02:24:59 am »
That is what I thought but I just wanted to be sure.  In the zip is an illustrator file.  I hope it is what you are looking for.
http://www-personal.engin.umich.edu/~stevebec/cp.zip
Good Luck.
Evilpenguin
  • MegaMame
« Reply #6 on: June 23, 2004, 05:32:52 am »
Thanks, that is exactly what I was looking for.  Thanks again.
Jason
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #7 on: June 23, 2004, 12:48:00 pm »
  How did you get the proportions correct in Adobe Illustrator?
-Steve
TalkingOctopus
    • My Arcade
« Reply #8 on: June 23, 2004, 09:49:51 pm »
First, I turned on the grid as well as the rulers.  I had the snap to grid option turned on.  Then I made some guides that defined the boundaries of the cp's dimensions.  Finally, I used the pen tool to make the outline.
