Author Topic: sound messing up in my athlon 2600 in dos window  (Read 1023 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: June 22, 2004, 01:25:52 am »
i have windows 98 and im running arcadeos/advmame and my sound seems like it slow's down sometime when playing...i have 256mb of ram a 30 gig drive and onboard sound. would the onboard sound be the issue?
SirPeale
  • Green Mountain Man
Re:sound messing up in my athlon 2600 in dos window
« Reply #1 on: June 22, 2004, 08:10:52 am »
Any particular games?
GMZombie
« Reply #2 on: June 24, 2004, 03:02:28 am »
most games i play they go from normal sound to slightly slower then back to normal and it keeps doing this randomly
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #3 on: June 24, 2004, 10:27:55 am »
RAM is not as important as CPU speed...
what CPU are you running?
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
« Reply #4 on: June 24, 2004, 12:39:57 pm »
What motherboard are you using? What onboard sound chip do you have.  I have a soyo dragon as well as on asus a7n8x-e both have the same issue with my 2600 mobile.  I beleive it had to do with heat issue with mine, because once I added different northbridge cooler, then put the old northbridge onto the southbridge, and then, found the audio chip and put a small heatsink on that, all my problems went away, but I had all the heatsinks already.  Going to buy them would have run 20 bucks, which at that point, you can get a sb live off ebay for that.
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
