Author Topic: I-PAC IMPORTANT Question *******  (Read 1510 times)
koolmoecraig
    • My Intervention
« on: June 21, 2004, 03:32:21 pm »
Hello all.
If I order the I-Pac USB from Ultimarc, is it just a USB adapter cable?
In other words, can I use it in PS/2 as well?
_Iz-
  • Last login:Yesterday at 10:53:39 pm
  • Time to coin up!
Re:I-PAC IMPORTANT Question *******
« Reply #1 on: June 21, 2004, 03:41:48 pm »
Hello all.
Mine was like that. (USB adapter cable + jumper to select ps/2 or usb mode).
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: June 21, 2004, 03:43:34 pm »
Hello all.
The I-PAC/2 or I-PAC/4 with the USB cable will work in either mode.  The I-PAC VE is USB only (no PS/2 support).
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« Reply #3 on: June 21, 2004, 04:01:50 pm »
Hello all.
do you recommend ve?  im thinking about purching this (other thread is ipac-xarcade)
i plan to use this is player 3/4 with 3 or 4 play buttons, a start button and credit button?
koolmoecraig
    • My Intervention
« Reply #4 on: June 21, 2004, 04:07:25 pm »
Does the same thing apply to the J-Pac USB???
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: June 21, 2004, 04:07:42 pm »
Hello all.
It just came out a couple of weeks ago -
Main differences -
32 inputs instead of 28 (Good)
RAM instead of EEPROM, so custom codesets have to loaded at each system boot (not a deal-stopper).
USB only - Probably better for your application, sometimes has problems, should be fine with newer hardware.
LED support, but I'm not sure how they hook up.
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: June 21, 2004, 04:14:31 pm »
AFAIK, yes (USB or PS/2 compatible)
