Author Topic: mamewah oproblems...mabye i need help  (Read 1271 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: June 18, 2004, 05:39:18 pm »
ok i start up mamewah and everything seems fine. i then goto start playing a game and when it says press ok to continue my keyboard will not work. it freezes? dunno if this is a advmame problem or a mamewah problem as if i use arcadeos it will work fine? thanx for any help.
Re:mamewah oproblems...mabye i need help
« Reply #1 on: June 18, 2004, 06:05:14 pm »
Try running MAME from a commandline to see if the same thing happens...
GMZombie
« Reply #2 on: June 18, 2004, 11:56:03 pm »
i have tried that and it dosent lock up....
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #3 on: June 21, 2004, 07:05:50 pm »
It is likely that mame is prompting you for something, in order to see the mame DOS box (normally hidden by mamewah) make sure you have the "show dos box" option set to True
(I can't remember the numeric equivalent, I haven't edited the cfg files by hand since I started using DButt's MameWah Setup utility).
There also used to be (haven't checked in the last few versions) a file called debug.log in the mamewah (or mamwah\files?) directory. It showed the command line used by mamewah to launch mame. try copying and pasting that line into a dos box to see if it works then (or post it here).
