Author Topic: run-time errors with mamewah  (Read 1107 times)
menace
« on: June 17, 2004, 01:38:22 pm »
This is a fresh install of win98 Se on a celeron 800 with 192Mb of ram and a 4Gb hard drive.  After I setup and run mamewah I either get a Run-time '28' out of stack space (on the first run) and run-time error '62' input past end of line for each subsequent try.  I've installed mamewah dozens of times and have never got this response--I'm assuming i'm missing some parts but have no idea based on these messages--any help?
Re:run-time errors with mamewah
« Reply #1 on: June 17, 2004, 01:40:54 pm »
No idea why you'd get 'Out of stack space'...
Delete the contents of the \mamewah\files folder and re-run.
Also, did you *install* MW or copy if from somewhere?
menace
« Reply #2 on: June 17, 2004, 02:20:01 pm »
It was a fresh install so i tried again with the same results ???  Then I copied the mamewah.cfg from another machine and up it popped--very weird....
« Reply #3 on: June 17, 2004, 08:15:05 pm »
Not sure what that was...delete the \files folder and try again..?
