Author Topic: power supply question  (Read 933 times)
Apollo
    • Eight Bells
« on: June 13, 2004, 03:48:24 am »
OK so I've got the Happ kiosk amp (12-18V 1.5 amp minimum) to power my arcade speakers. To power the amp I have an unregulated 13.8-18V 1.5amp power supply. I have a a question about what unregulated means and whether I can use the power supply for this amp. Help please.
Thankyou
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re:power supply question
« Reply #1 on: June 13, 2004, 09:23:32 am »
Unregulated means there are no electronics in the power supply to maintain a specific voltage output.  The power output of the supply could be anywhere in it's output range depending on the input voltage and the load on the supply.   The output of these units isn't very stable.
Generally  you wouldn't want to use an unregulated supply to power anything electronic.
You could use an unregulated supply to power light bulbs and things of that nature, since they are pretty forgiving.  But I wouldn't use it to run an amp.
D
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 13, 2004, 12:03:38 pm »
Actually you could use an unregulated power supply to run an amplifier for your application. Amplifiers generally don't need an exact voltage to run on, just something in the ballpark. Many of the Midway games like Rally-X picked up it's power for the sound from the unregulated side of the 12 volt power supply.
D_Zoot
« Reply #3 on: June 13, 2004, 02:11:52 pm »
What are you using for an amp ??
Car audio amps usually start to heat up and flake out at around 17-18 volts.   PC speaker amps probably won't handle much more than a few volts over the rating for any period of time without heat issues.
Ken you made an excellent observation.  However,  I suspect those boards are exceptions and would not suggest using an unregulated supply unless I knew the electronics were designed for it.
D
