Author Topic: Attaching AVGA to Monitor: What wires go where??  (Read 1618 times)
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« on: June 12, 2004, 05:56:42 am »
I have just received a 25" Kortek Monitor and have had it installed in my new cab.  I've got the Arcade VGA Card and I bought the breakout VGA cable to go with it.  I'm a little confused about the V and H connections to plug in.  The Kortek monitor I have has a connector on the circuit board with the following pins marked:
R  G  B  E  V+ H+      E   V-  H-
The VGA Breakout cable has  R,G,B, H, V & I.  Obviously the RGB connect to RGB, but do the V and H connect to the - or the + pins??  From what I've read on the ultimarc site, I think I should plug into the negative V and H pins, but I'm not sure.  I'm totally new to Arcade monitors so any help would be appreciated.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:Attaching AVGA to Monitor: What wires go where??
« Reply #1 on: June 12, 2004, 01:50:33 pm »
As a GUESS, I would expect E, V- and H- to go to ground which it looks like I is on your cable. Then you just connect RGB, GND and H/V+.
« Last Edit: June 12, 2004, 01:52:35 pm by DaveJ-UK »
menace
« Reply #2 on: June 12, 2004, 07:54:40 pm »
Just the E's go to ground (I on your cable)--then you hook up either the H+/V+ OR H-/V- depending on your monitor.  The wells gardner k7191 uses the H-/V- so you could start there--all you will get is no sync if you are using the wrong pair.
stuzza
    • ScreenshotArchive
« Reply #3 on: June 12, 2004, 11:00:53 pm »
Thanks for that guys.  I'll try hooking it up and see how it goes.  I can't wait to see what all the fuss is about with Arcade Monitors.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #4 on: June 13, 2004, 04:11:41 pm »
ArcadeVGA outputs negative sync signals. suggest try connecting wires H and V to H- and V- on the monitor. The I wire is ground. think that should go to E.
Some monitors expect a composite sync. advantages of AVGA giving negative syncs is that composite sync can be made by simple joining the  H and V wires together.
