Author Topic: Cutting a 2 1/4" hole in plexi for trackball.  (Read 2009 times)
djflip
  • Last login:August 25, 2004, 09:48:48 pm
  • M.A.D. CAB - "Dig Your Own Cab!"
« on: June 09, 2004, 04:28:58 pm »
Can this be done with a dremel using the circle cutting guide and the multipurpose bit?  I don't have a hole cutter that large (the biggest I have is 2").
Floyd10
Re:Cutting a 2 1/4" hole in plexi for trackball.
« Reply #1 on: June 09, 2004, 05:45:58 pm »
Well, I've never tested it... You should just play it safe and buy a new circle cutter.
djflip
« Reply #2 on: June 09, 2004, 06:15:12 pm »
well...i tried cutting it out of a small piece of lucite (6" x 6") and it warped the circle.  This happened because I didn't clamp the lucite onto anything...it was being held freehand (actually...the dremel was in one hand, while the other would rotate the 6"x6" piece of lucite).....
I think if i clamp the lucite onto a piece of wood that it should be fine.
Any comments / concerns?
Floyd10
« Reply #3 on: June 09, 2004, 06:17:14 pm »
lolololololol
djflip
« Reply #4 on: June 09, 2004, 06:30:13 pm »
I was anxious to get it done.....what can i say  :-[
Floyd10
« Reply #5 on: June 09, 2004, 06:31:13 pm »
Haste makes waste my friend
djflip
« Reply #6 on: June 09, 2004, 06:36:59 pm »
TELL ME ABOUT IT!!!!  :(
I picked up a forstner bit (thanks to the tip in the BYOAC book)....and it works so F'ing beautifully!!!  It's cool, cause when you're done, you're left with a thin little 1 1/8" token kind of thing......no use for it...but still cool nonetheless.
I recommend the Forstner bit for ANYONE who has a CP with any sort of button or joystick on it ;)
Floyd10
« Reply #7 on: June 09, 2004, 06:48:00 pm »
Cool, Ill keep that in mind
