Author Topic: TMNT/Simpsons question (another one)  (Read 1218 times)
CGRemakes
  • Last login:December 14, 2008, 12:52:09 pm
  • Free Frogger clone! (click on my sig)
    • Classic Game Remakes
« on: June 07, 2004, 12:41:06 am »
As mentioned before, I am in the process of getting supplies ready for my next arcade machine.  I am using the TMNT/Simpsons plans available from jakobud.com, and had a design question.  Overall, this cabinet is just what I'm looking for, but I have a design question.  I will be using this machine to play console games.  For the most part, I will be using 4 joysticks, but there are times when I will be using the standard console controlers (not all games work well with a cab).  The angle of the screen on this particular cabinet is approximately 45 degrees, which works great if you are standing there playing with the joysticks.  However, when I use the console controllers and am sitting 6 feet away or so, the angle of the screen will likely make it difficult to view.  I was thinking about increasing the angle of the screen to about 55 - 60 degrees (the angle of the standard Midway cabs) to make it more viewable from a distance.  Will the increased angle make it difficult for all 4 players to see when they are standing up close playing with the joysticks?  Am I incorrect in calculating that it will be difficult to view from further away at 45 degrees?
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
Re:TMNT/Simpsons question (another one)
« Reply #1 on: June 07, 2004, 03:39:01 am »
This is sort of a difficult question because you are trying to do something with a cabinet that it was not designed for.
It's like asking:
"Should I mount my cabinet's monitor upside down so that I can play when I'm hanging from the ceiling?"
I think your assumptions are correct, you just have to weigh out the different options and determine what is most important to you.
« Last Edit: June 07, 2004, 03:39:53 am by Jakobud »
Gameboy.au
  • Last login:January 11, 2005, 05:54:15 am
  • Cabinet completion: 65%
« Reply #2 on: June 07, 2004, 06:22:17 am »
As jakobud has said, it's a difficult question.
Depending on what monitor methoad your using (TV, PC monitor etc), don't have it completely fixed into the cabinet when 90% constructed.
This should allow you to alter the angle to suit both your needs.
The internet, hey... so they have that on computer's now???
CGRemakes
« Reply #3 on: June 07, 2004, 12:15:11 pm »
Ok, another option I can go with is to use the Mortal Kombat plans.  It appears as though the NFL Blitz '99 cabinet just uses the standard Midway cabinet with a wider control panel.
http://www.klov.com/game_detail.php?letter=&game_id=8819
Is this correct?  This would be better for viewing from a distance, but does it make it awkard for up close 4 player play?
