Author Topic: no vhold with arcade vga. tekkan board ok though...  (Read 2437 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: June 05, 2004, 06:44:06 pm »
I have a mk cab with a 25" monitor. when I play the tekkan 2 board it is fine. once I connect the arcade vga it will not hold.. is there a possible fix to this? it does not flip very fast.. I need help with this.. that and I have an nvidea mobo and it seems to wrteak havoc upon my xp install.. that another issue...
thanks
Paul Olson
    • Paul's Arcade
Re:no vhold with arcade vga. tekkan board ok though...
« Reply #1 on: June 06, 2004, 01:47:08 am »
What resolution are you running?  Try 640x480 for Windows desktop.  Some resolutions just don't seem to work. 401x256 rolls on mine, and it seems like quite a few games try to use that one.
Paul
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #2 on: June 06, 2004, 05:16:34 pm »
Are you sure you have installed the AVGA driver correctly?
Maybe the standard Windows XP ATI drivers are being used instead?
I had to boot in safe mode and install the AVGA drivers.
What monitor are you using? Maybe you need a video amp to boost the video signals? the AVGA output signals are 1v some monitors require a 5v signal. If you are using a JPAC i think it does this for you.
Knoxximus
  • Last login:December 19, 2011, 12:22:58 am
  • Young Frozen
    • Beat-TECH Productions
« Reply #3 on: June 06, 2004, 07:30:20 pm »
thanks
I was having the same damm problem (See "Roll and Stop" thread).  I tried everything that the forum members suggested without success.  I figured that they were getting sick of my B'n and moanin' so I hit up the man himself, Andy Warne of Ultimarc.  He thinks the problem might be from the Video Amp, with the idea that maybe my monitor needs a "+ "sync, and the Video Amp outputs "-" (or something like that).  I have to mail my Amp back to him....*sigh*....the unbearble wait for arcade glory continues..... :'(
Dumb questions deserve dumb answers.
delta88
« Reply #4 on: June 07, 2004, 10:33:11 pm »
But im not usin a video amp. the desktop is displaying at 640x??? (forgot)   I have the r g and B hooked up to the r g and b of the monitor. Then I hooked the + and - up to the + and - of the monitor as well.. i think..... its a very slow rolling.
am i sappose to combine um or what? it is a WG monitor :)
thx
 d88
Knoxximus
  • Young Frozen
« Reply #5 on: June 08, 2004, 03:32:32 pm »
Yeah, actually try wiring the monitor +/-  to just the negative sync on your card.  If that doesn't do it, try the positive sync on your card.  If that doesn't do it, then maybe someone like Ken Layton can be of more help.
Paul Olson
    • Paul's Arcade
« Reply #6 on: June 09, 2004, 02:09:09 am »
Set it to 640x480 interlaced for the windows desktop.  That should hold.  If it doesn't, you will need to adjust the monitor.  My Tekken 2 has a WG 25k7191 monitor.  I couldn't tell which pot to adjust by looking at it.  This page has a link to the manual, if you have the same, or probably similar, monitor, it will tell you what to adjust.
Hope this helps,
Paul
http://link.mywwwserver.com/~jstookey/arcade/WG_25k7191/
