Author Topic: Smash TV and iPac  (Read 1533 times)
JAZ
  • Last login:August 03, 2013, 12:16:52 pm
Smash TV and iPac
« on: June 04, 2004, 12:19:27 am »
How do you connect four 8-way joysticks (2 per player) for games like Smash TV and Total Carnage to an iPac? Do you need an iPac4 which supports four sticks? I guess you just connect joystick 1 (player 1 movement) and joystick 2 (player 2 movement) as normal, but what about the other 2 sticks?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Smash TV and iPac
« Reply #1 on: June 04, 2004, 12:23:29 am »
You could use an ipac2, just mape the other joysticks to button inputs.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: June 04, 2004, 12:24:11 am »
Couldn't you use some of the player 1 button connections for the second player 1 stick and then configure it in Mame?
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« Reply #3 on: June 04, 2004, 12:27:25 am »
Here's a simple solution for an ipac2...
For Player 1, connect one joystick to the directional keys, and connect the other joystick to 4 of player 1's  non-directional keys and just setup the buttons in mame.
For example:
        Left Joystick:                              Right Joystick:
             UP                                               ALT
LEFT                 RIGHT            CTRL                       SPACE
           DOWN                                            Z
The same idea would go for player 2.
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #4 on: June 04, 2004, 01:15:04 am »
You just map the input controls on those games accordingly.
If you have a control panel layed out in a fashion 3124
Player 3 stick = 1 - left
Player 1 stick = 1 - right
Player 2 stick = 2 - left
Player 4 stick = 2 - right
