Author Topic: Help removing PCmonitor from case  (Read 1069 times)
wakerlet
  • Last login:September 25, 2007, 11:37:53 am
  • 1-2-3-4..thats the combination on my luggage
« on: June 01, 2004, 02:22:32 pm »
All,
I hope you can help me out.  I've decided to mount my pc monitor, caseless, in my cabinet.  The problem is, the control board is connected to the tube in quite a few different places.  Is there someone out there who can tell me if I need to remove the suction cup piece shown here?
Any other tips would be helpfull.  There are so many wires!
wakerlet
Re:Help removing PCmonitor from case
« Reply #1 on: June 01, 2004, 02:24:59 pm »
Also what about removing the base?  I can't see how it is attached.
menace
« Reply #2 on: June 01, 2004, 02:44:24 pm »
Follow the discharge procedure and defang the monitor before doing any work on it--the rest of the wires should be inert AFTER you do this--just take lots of digital pics and unplug the molex connections as needed.  I found it easier to mount the pc monitor as a unit however and avoided disconnecting all the wires--different monitors require different procedures i guess.
As far as the base goes, that little tab in the forfront of the second pic is usually a plastic spring clip--pull it down then slide the base back to unattach it--it may be on there good so you might have to fiddle with it.
