Author Topic: need some explanations on renaming roms with goodtools, etc.  (Read 1160 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
okay, i have downloaded marquees, and im sure that they are not the same names as some of my roms/screenshots.  my question is, what is the best way to make sure everything appears correctly....as in screenshots, and marquees together?  how does it know what marquee to show when i select a game?
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
Re:need some explanations on renaming roms with goodtools, etc.
« Reply #1 on: May 31, 2004, 05:14:15 pm »
Image files need to be labeled the same as the rom name.  ;)
If you got your collection from a Mame Burner then this should already be done for you.
hulkster
« Reply #2 on: June 01, 2004, 10:01:07 am »
okay, i found some marquees, but there are several missing.  is there the "end all" place to get the marquees for most mame games?  i know klov has them, but i want to download all of them in one, or several zip files.  suggestions?
