Author Topic: 5/8" plywood - where the hell is it?  (Read 1044 times)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« on: May 29, 2004, 07:49:53 am »
(Plywood in the following post is the smooth finish-grade plywood, maple I believe)
So I check through 2 local home depots. NOTHING is 5/8".
I found one pile of MDF that is 5/8", but I really would rather use plywood since it's really NOT that much more expensive in the scheme of things (I'd rather spend the extra $60 on plywood instead of a better computer component if you're following THAT thread ;)
So, I came up with 1 5/8" pile of MDF, and about 5 different piles of 3/4" plywood, and 2 piles of 3/4" smooth particle board.
Should I start checking other lumber yards for 5/8" plywood? I don't really mind building the cabinet out of 3/4" I just think it's overkill, and I based my plans off of lusids (doesn't everyone?) which is based on 5/8" wood being used.
The other problem comes, where if I DO use 3/4" plywood, I still want 5/8" for the top of the control panel since it will have lexan on top. So I'll at least need a SMALL piece of 5/8".
So what do you think, should I just give in and get 3/4" for the whole cabinter, and get whatever I can 5/8" for just the top piece of the control panel.
BYOAC users get 5% off with coupon code byoac5
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
Re:5/8" plywood - where the hell is it?
« Reply #1 on: May 29, 2004, 11:34:57 am »
My local HD and Lowes never have 5/8" either.  You can try a "real" lumberyard, they will probably have it.  But you can easily use 3/4", it really just makes it heavier.  If you are determined to use 5/8" for the cp you can use MDF if you can't find any plywood.
Next I'll be on fries, and that's when the big money starts rolling in.
Sylentwulf
« Reply #2 on: May 29, 2004, 04:35:25 pm »
Most likely it looks like this is what I'm gonna have to end up doing.  The purpose WAS to make it a lot lighter, but I suppose at least plywood is lighter than MDF. Ahh well....
