Author Topic: electric eye / infrared switch?  (Read 3630 times)
jagnogg
  • Last login:November 03, 2006, 01:43:21 pm
  • I'm not wearing any pants.
« on: May 28, 2004, 10:10:49 am »
Does anyone know where I can purchase a switch that is triggered by an infrared light beam being broken? Something that I could connect to an IPAC in the same way other microswitches connect.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re:electric eye / infrared switch?
« Reply #1 on: May 28, 2004, 10:40:10 am »
Somthing like this?
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: May 28, 2004, 10:48:49 am »
If you mean for detecting coins, you could try here and build one.
jagnogg
« Reply #3 on: May 28, 2004, 10:48:56 am »
Somthing like this?
Not exactly. I'm looking for something like what you see on a garage door opener. The switch is triggered when the beam of light is broken. Wave your hand through the beam and it acts just like a button being clicked.
rsoandrew
  • Last login:February 24, 2018, 09:02:10 am
  • Worldwide travelling Mame Machine
    • Andrew's Arcade
« Reply #4 on: May 28, 2004, 11:16:14 am »
What's the actual application for what you're trying to do? You might get some better suggestions.
Otherwise, most alarm parts work in this manner. You could get a PIR (probably get a used one for free if you talked to an alarm installer) and focus a very narrow beam (just use tape inside the lens). Most of these can function as either a Normally Open or Normally Closed switch and use 7
