Author Topic: NES Light Gun Adapter  (Read 3040 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« on: May 25, 2004, 03:22:54 pm »
I have been working on an NES adapter and began wondering if there is a way to hook up an old NES light gun to a computer. It would seems that if you can create a port that works with the NES controller it should be able to work with the light gun as well (since it worked off the same port in the real NES). Here is a link to the adapter I am going to be making, except I am modifying the plans to an old NES controller socket so I can unplug the controller if I want.
http://snespad.emulationworld.com/nes_adapter.html
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
TalkingOctopus
    • My Arcade
Re:NES Light Gun Adapter
« Reply #1 on: May 25, 2004, 08:03:56 pm »
I really wish that you could connect the NES lightgun to a computer but there are a few things that prevent that possibility.
1) The gun works on a TV only not on a computer monitor.
2) There is no driver for it.
Tahnok
    • Table Arcades
« Reply #2 on: May 26, 2004, 02:49:21 am »
Hmm... well... most people on this forum are using TVs as monitors. So that shouldn't be a problem.
As for the driver, yes, that is a problem. I wonder where I could find a programmer willing to try out this experiment.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #3 on: June 07, 2004, 11:46:15 am »
To do this would be quite the undertaking. A Lightgun requires that the screen "flash" for a moment, which then the light gun reads in the location, based on where the flash is at the time. (Read up on Monitors if you want to understand this more)
The NES actually worked a little different, as the screen blacked, and the targets whited out, which would make it easier to program for.... well, duckhunt.
But meanwhile, You have to be able sync the monitor refresh rate and the reading of the gun. The act-labs pc and tv gun have a passthrough which adds the flash to the screen, and does the location calculation internally, I believe. This means you would need to design an actual piece of electronic hardware.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
