Poll
Is your control panel flat or sloped?
Total Members Voted: 0
Author Topic: Control Panel - Sloped or Flat?  (Read 2594 times)
dema
  • Last login:September 02, 2014, 03:05:34 am
« on: May 24, 2004, 09:15:07 am »
I'm building a mock-up of some rotating control panels and I needed to know whether or not you have/prefer a flat or a sloped control panel.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
Re:Control Panel - Sloped or Flat?
« Reply #1 on: May 24, 2004, 09:32:00 am »
most cp's are sloped....but its a very small slope.  the standard is about 1" slope, so if your cp box underneath is 7" tall at the top of the slope, then the front is 6".
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #2 on: May 24, 2004, 09:41:35 am »
I went with the 1" slope as well, with a reasonably deep control panel (I wanted it to fit exactly in a trunk, so about 2' deep or so).  The slope "felt" better than a flat plane.
-->VPutz
AlanS17
    • AlanS17
« Reply #3 on: May 24, 2004, 09:58:37 am »
My first machine's CP was totally flat, but I never got any complaints from the 100 or more people who played it. It just fit better with that machine, though. I Imagine the next machine will be sloped. It's just whatveer fits your machine, and what looks right on the machine.
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #4 on: May 24, 2004, 03:01:13 pm »
MY Soul Edge jamma cab is sloped 1.5"-2" (I forget) and I plan on mine being sloped 1.5"
I'm short. If it's not sloped, I DON'T like it.
BYOAC users get 5% off with coupon code byoac5
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #5 on: May 24, 2004, 03:22:12 pm »
Mine has about 20o of slope which is more than most, but I also have two rows of controls, so it works for that.  I think you need a little slope to be more ergonomic.  I played around with a "cardboard prototype" for a while to make sure it felt right, before committing it to wood.
dema
« Reply #6 on: May 24, 2004, 03:25:22 pm »
I'm 6'2" so I wasn't sure if I should slope it or not. In terms of the woodworking, I think it would be easier and faster to make rotating panels with a flat surface but I wasn't sure if after all that work I'd hate the fact that it doesn't rotate properly or feel right.
I'm planning on making each panel 32" wide and 16" deep. Hopefully I won't have to redo this too many times.
« Last Edit: May 24, 2004, 06:35:08 pm by dema »
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« Reply #7 on: May 24, 2004, 03:27:24 pm »
If possible, mine will be sloped enough to prevent anyone from setting a glass of Kool-aid on my CP...
_Iz-
  • Last login:Yesterday at 09:14:29 pm
  • Time to coin up!
« Reply #8 on: May 25, 2004, 12:16:35 pm »
My Final Fight arcade cabinet has a 9
danny_galaga
  • Last login:November 24, 2025, 05:39:37 am
    • dans cocktail lounge
« Reply #9 on: May 27, 2004, 11:24:53 pm »
yes, mugzillas reason may be the most important of all! hadnt thought of that. having a cocktail though means i have a p[lenty big enough glass surface for beers n chips...
still mine is sloped.
danny_galaga
« Reply #10 on: May 28, 2004, 05:43:40 am »
gee, must remember to reduce the size of pics here. the one i posted is pretty annoying i must say...
« Last Edit: November 24, 2025, 05:00:49 am by danny_galaga »
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #11 on: May 28, 2004, 08:14:07 am »
Its a matter of preference, but I think 10-15 degrees is about right.
Doc-
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
« Reply #12 on: May 28, 2004, 05:52:44 pm »
I think it's a matter of height.  If the CP is lower (around waist level) then having it flat would be best.  If it's a little higher, then having it sloped would be more comfortable/ergonomic...
Still in the collecting parts and ideas phase of cabinet building.
