Author Topic: Need some suggestions  (Read 2131 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: May 19, 2004, 12:19:30 pm »
Well now that I have my ps2 and dc
I want to wire them to my controls. Here is the problem (potentially) I'm using the hagstrom encoder and I'm not sure how what would be the best way to connect the controls and then switch between them.
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
If no one feeds the trolls, we're just going to keep eating your goats.
Shieldwolf
  • SpearShield.com
Re:Need some suggestions
« Reply #2 on: May 19, 2004, 12:43:17 pm »
maybe I should be more clear. I am aware of the switch box, however I'm not sure it is feesible for what I want.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #3 on: May 19, 2004, 12:46:37 pm »
Yeah, this is discussed here alot and you'll find lots of info on it. There's several good web tutorials on the subject.
I went the simplest way. The CP disconnects from the encoder and then reconnects to the DC. You just reach in and disconnect/reconnect. I didn't bother with a switch or anything fancy. you just need to decide on some sort of universal interface for the CP to connect with (e.g., a DB25 or Molex connectors or whatever) and then wire consistantly.
Have fun!
Shieldwolf
  • SpearShield.com
« Reply #4 on: May 19, 2004, 12:52:20 pm »
but will that work with the hagstrom endcoder? I hadn't seen one done with it yet.
abrannan
« Reply #5 on: May 19, 2004, 12:54:47 pm »
It will work with *any* encoder.  All you are doing is switching the wires from the buttons to the encoder.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #6 on: May 19, 2004, 03:36:37 pm »
just to clarify what everyone else is saying, the break in the cabling (bd25 or molex or whatever) comes before the encoder so it goes:
...............................>ps2
controls>connector>encoder
...............................>dc
hope that helps
Mooters
  • Last login:April 08, 2005, 02:48:35 pm
  • I Hate Mondays, I LOVE MOZZY (MOZILLA)
« Reply #7 on: May 19, 2004, 05:54:35 pm »
_____________                                             ______________
|                        |                 _______             |                          |
|   Controls        |________|          ||||______|                          |
|                        |________|Molex ||||______| DC/PS2/PC        |
|                        |                |_____||||            |                          |
|____________|                                            |                          |
        |_____________|
Sompthing like this diagram is what I understand.
Spyder
The Game Is NEVER Over!!!
Shieldwolf
  • SpearShield.com
« Reply #8 on: May 19, 2004, 06:39:57 pm »
right the only reason i had concern was because of the breakout boards on the hagstrom encoder, but if you guys say it works then it does.
