Author Topic: Slot cutter size for 1" t-molding?  (Read 951 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: May 19, 2004, 10:07:15 am »
i am building a cocktail cab with 16mm MDF so will need 5/8" t-molding for main parts of the cab. however will probably go for 1" thick table top. I see that 1" t-molding requires a different size slot cutter than the 5/8".
Can i "make do" with using a 1/16" slot cutter for both width t-molding?
JustMichael
  • Mmmmm!! Cheesecake!!
Re:Slot cutter size for 1" t-molding?
« Reply #1 on: May 19, 2004, 12:39:14 pm »
Yes, you can make the slot widerer by adjusting how far the slot cutter is below the router and cutting the slot again.  I would suggest adjusting the slot cutter so it cuts the correct distance between the top of the wood and the groove.  This will probably make the groove off center.  Next you flip the piece of wood upside down and recut the groove.  This will center the groove.  If the groove is so wide that there is stuff left in the middle, just adjust the slot cutter's depth to match this stuff and cut again.  Do this AFTER cutting the dual grooves on all pieces that need the wider slot though.  Make sure to practice and get the fit right on a scrap piece first before you try on the real piece you want slotted.
Apollo
    • Eight Bells
« Reply #2 on: May 19, 2004, 05:08:54 pm »
Or if you want to buy the correct slot cutter it is a 5/64" blade. Available from www.t-molding.com and other places.
