Author Topic: Advmame trouble with one set of resolutions  (Read 1406 times)
menace
« on: May 18, 2004, 09:37:33 am »
So I got advmame all set up using the trident and Jpac and all the video modes look good except 1: 288x224--namely pacman, galaga and company.  I created a custom resolution of exactly 288x224 at 60.06 hz and without fail advmame chooses 400x272 (a generated mode) for all games in this resolution class.  and if i pick 288x224 manually it doesn't look so hot--I'm quite frustrated now.
So for those of you running advmame, what resolution did your advmame pick for pacman etc.?
« Last Edit: May 18, 2004, 09:37:52 am by menace »
menace
Re:Advmame trouble with one set of resolutions
« Reply #1 on: May 18, 2004, 12:53:55 pm »
nevermind--got it figured out
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: May 18, 2004, 03:07:09 pm »
Pleae share your solution. However obvious, it may help someone who use the search.
menace
« Reply #3 on: May 18, 2004, 03:44:37 pm »
I cheated--I made pacman fill the screen without distrortion by using the monitor controls, then i went back into advv and reconfigured all the other resolutions to fill the screen--took awhile but they all look good now.
