Author Topic: 49 way joystick question  (Read 1016 times)
Aceldamor
« on: May 17, 2004, 09:27:17 pm »
I know there is a product you can buy that will translate the old Sinistar/ new Blitz joysticks, but will it work on the arch rivals sticks?
« Last Edit: May 17, 2004, 09:30:30 pm by Aceldamor »
Fuzzy Wuzzy was a woman!
OSCAR
    • Oscar Controls
Re:49 way joystick question
« Reply #1 on: May 17, 2004, 09:37:40 pm »
The Arch Rivals stick is essentially the same as Sinistar.  The notable differences are that the Arch Rivals stick has 3 slots cut in the mounting plate instead of the 2 slots in a Sinistar stick, and it uses a later rev optic board.  Other than that, they are the same.  Electrically the two are compatible, so they should both work just the same with the pc interface.
Aceldamor
« Reply #2 on: May 17, 2004, 10:16:16 pm »
Thx Oscar.....I'm prob gonna buy them, but they have an orange ball top on them  :(
ani
  • Last login:June 17, 2004, 05:29:21 pm
« Reply #3 on: May 18, 2004, 05:07:15 am »
I've got 4 of the blitz ones, i'd let go of 2 of them if ya want.
Lilwolf
« Reply #4 on: May 18, 2004, 08:23:52 am »
btw, the outputs are different.  There had to be some changes to Daves board to get it to work with both.  (I don't know the difference, but I think its one is 0100 and the other is 0111 for the same position.)
Anyway... a bigger quesiton
Anyone figure out a good over the shelf cable to plug into it for hacking?
