Author Topic: new mamewah  (Read 1529 times)
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
new mamewah
« on: May 15, 2004, 12:15:31 pm »
I have downloaded the new mamewah and I have one question......How do i replace the existing mamewah with the fewist headaches? I have multiple emulators configured with screenshots ect, and I would prefer not to start over. Can I just replace the executable?
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
Re:new mamewah
« Reply #1 on: May 16, 2004, 09:03:47 am »
You can just replace the executable....
...but your old CFG files will not work :(  You could print out the contents of your old CFG files, and then add the details into your newly generated CFG files.  Alternatively, you could wait for a new version of David Butlers 'MAMEWAH Setup', which should be able to convert the CFG files for you.
At some point I must have a go at making the CFG files backward compatible...
btoddkelley
Re:new mamewah
« Reply #2 on: May 16, 2004, 10:42:26 am »
well, I didn't like the answer but i appreciate the responce!
Todd
- Descartes
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
Re:new mamewah
« Reply #3 on: May 16, 2004, 03:19:43 pm »
Just updated MAMEWAH setup.
So you should be able to update your config files without moving a muscle. ;D
Well apart from clciking the mouse button a few times. :)
www.mamewah-setup.co.uk
btoddkelley
Re:new mamewah
« Reply #4 on: May 16, 2004, 05:18:45 pm »
I had just discovered your update before you posted, David.  I don't know which is better, the new Mamewah or the fact that Mamewah set up fixes your configs in about 3 seconds.
 The only drawback is now my mouse-clicking finger is really hurting! :D Thanks for the great programs!
Todd
- Descartes
