Author Topic: Mamewah- no snaps showing?  (Read 1106 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: May 12, 2004, 11:26:31 pm »
Hi
JUST building new cabinet and for some reason mamewah worrks but my snaps are not showing. I have them in D:\screenshots\mame\snaps\ and in the emu artwork config file I have it set to that.. not working???? any ideeas why they would suddenly disappear.? yes there are pngs in the folder named correctly.
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
Re:Mamewah- no snaps showing?
« Reply #1 on: May 13, 2004, 02:13:25 am »
Did you do a proper install of Mamewah or copy the folder from another comp?  Make sure you have the PaintX.dll in your system (I think) folder.
« Reply #2 on: May 13, 2004, 05:21:11 am »
Yes, I bet you just copied over your MAMEWAH folder from a different PC didn't you?...
Easiest thing to do is *install* MAMEWAH and then copy the \Files folder from your other PC.  The installation process installs & registers PaintX.dll - or you can do this manually if you are comfortable using regsvr32.
