Author Topic: quick mame ini control question  (Read 1795 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: May 12, 2004, 06:37:37 pm »
How do you type the keycode for this command?
P1_JOYSTICKRIGHT_UP
I want the up and right arrow on my keyboard for that command
How does it need to be written exactly so it will work?
Tiger-Heli
    • Tiger-Heli
Re:quick mame ini control question
« Reply #1 on: May 13, 2004, 07:14:43 am »
P1_JOYSTICKRIGHT_UP
I'm assuming here that you have ctrlr.ini files set up and working, and that you want the P1_JOYSTICKRIGHT_UP (up right joystick on a 2 joystick game like Robotron or assault) command mapped to "the up and right arrow keys"
Line should read
P1_JOYSTICKRIGHT_UP "KEYCODE_UP KEYCODE RIGHT"
This gets placed in either the default.ini or gamename.ini file in you ctrlr files directory.
See http://www.mameworld.net/easyemu/mamecontrolini.htm for more info.
ErikRuud
« Reply #2 on: May 13, 2004, 10:16:18 am »
The information above is correct.
However...
You probably do not want to do that for Robotron. If you do, you will have to move the right stick to a diagonal (up and right) to go UP.
P1_JOYSTICKRIGHT_UP is the retting for UP on the righthand stick.  It is NOT the setting for the Right Up diagonal direction.
Robotron should be setup like this:
P1_JOYSTICKLEFT_UP          "KEYCODE_UP"
P1_JOYSTICKLEFT_DOWN        "KEYCODE_DOWN"
P1_JOYSTICKLEFT_LEFT        "KEYCODE_LEFT"
P1_JOYSTICKLEFT_RIGHT       "KEYCODE_RIGHT"
P1_JOYSTICKRIGHT_UP          "KEYCODE_R"
P1_JOYSTICKRIGHT_DOWN        "KEYCODE_F"
P1_JOYSTICKRIGHT_LEFT        "KEYCODE_D"
P1_JOYSTICKRIGHT_RIGHT       "KEYCODE_G"
This setup works for Robotron, Crazy Climber, Black Widow, Battle Zone and other 1 player dual joystick games.
American Laser Games Wrapper
O2em Rom Utility
Shieldwolf
  • SpearShield.com
« Reply #3 on: May 13, 2004, 11:00:33 pm »
do right_up is not diagnol right  but rather up on the right control?
ErikRuud
« Reply #4 on: May 13, 2004, 11:06:41 pm »
Exactly!
right_up is up on the right control.
left_up is up on the left control.
O2em Rom Utility
