Author Topic: BYOAC 2004 Custom Token Design Thread.  (Read 122423 times)
Pixelhugger
  • Last login:February 11, 2026, 06:45:00 pm
Re:BYOAC Custom Token Design Thread.
« Reply #200 on: May 13, 2004, 04:32:18 pm »
Reverse lay up bling.
Project mega thread HERE
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« Reply #201 on: May 13, 2004, 04:33:11 pm »
DOUBLE BLING!
Man, when it's right, it's right...gave me goosebumps, it did, both of them.
I think we need a different phrase than "good for extended play," though.
Kevin
« Last Edit: May 13, 2004, 04:35:04 pm by kevsteele »
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
Pixelhugger
« Reply #202 on: May 13, 2004, 04:33:45 pm »
Reverse lay up blingity bling.
Surgeville
  • Last login:October 18, 2025, 12:30:21 pm
  • Always so close, yet so far!
« Reply #203 on: May 13, 2004, 04:34:30 pm »
Double bling.
I just have one question for you to consider.  The bottom of your token design is darker than the top.  I don't know if that is possible without coloring, which raises the cost.  At least when I bought mine from Hoffman.  The darkness when they look at the design has to do with how deep a cut it is.  So, how your design is now, the bottom half would have Pacman and pellets go in and the top half would have Pacman and pellets stick out.
If the darkness of the bottom is just supposed to be how the light is reflecting forget I mentioned this.
Chris
    • Chris's MAME Cabinet
« Reply #204 on: May 13, 2004, 04:36:44 pm »
Double bling.
That's just part of the "bling" effect.
--Chris
Pixelhugger
« Reply #205 on: May 13, 2004, 04:37:22 pm »
Yep. But you raise a good point in that these images are probably FAR more reflective than the actual tokens would be... which I imagine would have more of a matte finish?
Surgeville
« Reply #206 on: May 13, 2004, 04:38:18 pm »
Double bling.
Sounds good then.  Just one more thing...How would it look with the bottom or the top Pacman being substituted with Ms Pacman?
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #207 on: May 13, 2004, 04:39:35 pm »
Yes, but I am pretty sure they will be real brass, and thus polishable.  In case you wanted to display them or something. I am going to ask abou that to be sure.
« Last Edit: May 13, 2004, 04:40:26 pm by Santoro »
Pixelhugger
« Reply #208 on: May 13, 2004, 04:40:43 pm »
Certainly doable if there's interest. I'm a little nervous about making it to PacMan oriented, tho. Otherwise either Ms. PacMan or a Ghost would look very cool.
Chris
« Reply #209 on: May 13, 2004, 04:40:52 pm »
I think I like the back without the stipple... contrasts with the front nicely.
Here's the side-by-side.  Thanks for the bling, Pixelhugger!
« Last Edit: May 13, 2004, 04:41:25 pm by Chris »
--Chris
Chris
« Reply #210 on: May 13, 2004, 04:44:15 pm »
I like it the way it is.  Pac-Man is relatively abstract; MS. Pac-Man or a ghost is very specific.
--Chris
KevSteele
« Reply #211 on: May 13, 2004, 04:47:32 pm »
The more I've seen of the "double Pac-Man" design, the more "infinity" it seems, and the more appropriate. Definitely in the spirit of "The Game is Never Over"
Speaking of which, I think "The Game is Never Over" phrase (or Better Living Through Gaming) would be good side text on the Player 1 side of the coin. Or both?  :o
Kevin
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #212 on: May 13, 2004, 04:47:54 pm »
I think Pac Man is more recognizable to the general population than Ms. is.
Chris
« Reply #213 on: May 13, 2004, 04:51:47 pm »
I think that the "No cash value" and "Good for..." phrases make it much more realistic and tokeny.
--Chris
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #214 on: May 13, 2004, 04:52:37 pm »
Tokens Direct just emailed back, already.  Survey says: Real Brass!
I am very happy with the customer service so far.
Chris
« Reply #215 on: May 13, 2004, 04:53:46 pm »
Polish and frame those puppies!
--Chris
Pixelhugger
« Reply #216 on: May 13, 2004, 04:56:50 pm »
Before the design decision solidifies any further, should we send a jpeg of the designs for them to approve as reproducible at our price point? Just a thought. I'm a bit nervous about the size of the "build your own arcade controls" type, but making it larger really impacts the size and placement of the BYOAC.
KevSteele
« Reply #217 on: May 13, 2004, 04:59:20 pm »
I just don't see the need for them on home-use tokens, but I'm not that adverse to them, just the "extended play" phrase, which isn't realistic or tokeny.   :P
Good for One Game, perhaps?
Kevin
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #218 on: May 13, 2004, 05:00:35 pm »
PH, I was thinking that as well, but was waiting for the right time.  Now is probably it.
I'll send them out right now.  This will probably be sent to the engraver to look at as opposed to the saleswoman I have been dealing with  so I am not expecting a ten minute turnaround on this one.
Stay Tuned
Pixelhugger
« Reply #219 on: May 13, 2004, 05:04:17 pm »
Stay Tuned
Maybe I should post them as line art so they don't get confused by the embossing of the bling effect. Bit more accurate for their purposes and probably how they are used to proofing things?
Calawala
  • Last login:July 08, 2004, 07:32:54 pm
  • I'm not a llama. I'm a donkey.
« Reply #220 on: May 13, 2004, 05:06:53 pm »
 :o
Wow... you've been busy!!!  The BYOAC pac-man design is my new favorite, along with the atari player1 for the second side.
A suggestion, since the font my be a little small...
In post 156, middle right, the BYOAC is a bit smaller (which I like since it doesn't crowd the coin as much), and the font is bigger and more evenly spaced out.  How about using that layout, but replace the atomic with the pac-man zen?
- Calawala
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #221 on: May 13, 2004, 05:06:57 pm »
Pixel, It can't hurt.  They want 300 DPI.
« Last Edit: May 13, 2004, 05:16:17 pm by Santoro »
KevSteele
« Reply #222 on: May 13, 2004, 05:08:51 pm »
Actually, thinking about it, perhaps the text on the player 1 side of the token could be put up for a vote as well?
A number of "quotes" could be polled, and one picked for the side text slogan on the player 1 side?
Both designs, as far as I'm concerned, are perfect as is. About the only thing I see to vote on is "stippling or no stippling"  ;D
Kevin
Calawala
« Reply #223 on: May 13, 2004, 05:18:15 pm »
I kinda like the stipple effect on the atari side.  Either way though, this coin is gonna be mint.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #224 on: May 13, 2004, 05:31:32 pm »
Just tossing in some more ideas:
- shrink the BYOAC so it fits inside the inner circle and then there is enough room for the slogan
- make the start button half depth to make the O look more "o-ish". This will also make the player 1 guy less deep so it won't lose form due to the inverted image
- maybe also the pacman and dots at half depth (I guess gray in the line art instead of black)
- put the slogan on the top and the url on the bottom (dunno why but it really looks weird to me this way around)
- I think a shiny background will look better on the actual coin then the stippled effect (even though in the image it might be different)
- the lines on the front and back don't seem of the same thickness
« Last Edit: May 13, 2004, 05:33:14 pm by patrickl »
AmericanDemon
  • The Reason the short bus was invented... 100% Slacker Guaranteed, 4:20 yet?
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
« Reply #225 on: May 13, 2004, 05:38:21 pm »
Yeah those are awesome.  I may have to order 2 sets!
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #226 on: May 13, 2004, 05:44:40 pm »
I love the current design.  I do like the idea of swapping the bottom Pac for a Ghost Monster.
BASSOFeeSH
  • Last login:May 29, 2009, 12:46:42 am
  • TD-2779
    • Trooper Armor
« Reply #227 on: May 13, 2004, 05:55:27 pm »
Those designs ==  8)
Calawala
« Reply #228 on: May 13, 2004, 06:04:52 pm »
I really love the current designs.  This next design is more of a "what would it look like" as I liked AmericanDemon's design he made at the start.
Chris
« Reply #229 on: May 13, 2004, 06:18:28 pm »
For a text size comparison, here's our tokens against real tokens:
--Chris
AmericanDemon
« Reply #230 on: May 13, 2004, 06:25:35 pm »
I can't say enough about how much I really like the designs set forth.  I didn't like them initially, but with all of the tweaks and the mockups....  they rock.  Mine was too bland.  :)
crashwg
« Reply #231 on: May 13, 2004, 06:35:56 pm »
I for one think the text on both sides of the coin look perfect.  Although it would be a good idea to see if the minting company can do text that size.
Also, I'd like to bring up the color choice again because it seems as though people are designing in brass and no one has realy expressed their opinion on the color choices.
I for one prefer the nickel (that's what it is right, the silvery lookin one...) and I think this should be put to a vote also.  It was mentioned that it would probably cost more though, so that the price should be investigated and included in the voting process.
I must applaud those who have inputted their ideas, esp. pixelhugger and chris.  If you don't work in the visual arts industry now, you deffinitely should!
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Calawala
« Reply #232 on: May 13, 2004, 06:45:00 pm »
I don't necessarily want to go with what I am posting below, not even sure why I'm posting it.  Just doing it in the spirit of comparison I guess.
#209 is the best
AmericanDemon
« Reply #233 on: May 13, 2004, 06:54:14 pm »
I agree as well.  We should vote on it.  Hey Pixel can you or Chris post those back up in the Silver/Nickel finish?
SirPeale
« Reply #234 on: May 13, 2004, 06:57:42 pm »
There's going to be a voting poll coming up.  A lot of really great designs are in right now.  Likely Sunday will be the cut-off date.  Santoro can tell you more about this plan than I.
DPsx7
  • Last login:May 12, 2004, 07:07:05 pm
« Reply #235 on: May 13, 2004, 07:00:13 pm »
Personally, I think post #97 is a good choice, but again, without the "building your memories" slogan. I don't know what else we'd use, but for some reason it just doesn't feel right to me.
#161 isn't bad either, but I think the URL would be better in lowercase. Having everything in caps makes it all look too similar I guess. I mean with lower case it sets the URL apart without straying too far.
Some of the other designs are nice, but if we get too complicated, it'll ruin the token. Such as using a P1 button as the "O" in BYOAC. It might be a bit much with all the rest going on.
The text on #177 is nice, maybe we can use that on another design. The only reason I say this is because some people didn't want MAME on there since we don't all use it and it was kinda specific. Instead, a Pac Man isn't considered as specific? The designs are all cool, but I'd rather tie the token to something a bit more open like MAME instead of a character.
I'll wait to see more of the designs later since you guys are constantly revising them. We will need a back to back view of all popular designs too, so we can compare them and trade pieces to create one awesome coin.
Pixelhugger
« Reply #236 on: May 13, 2004, 07:24:38 pm »
I'd be interested in the cost of nickel plating as well. Although I guess more would accidentally find their way into cash registers (a la canadian pennies) than with the brass. :P
Below is nickel plated without stipple.
(remember these are simulations, actual tokens may not be this shiny!)
Pixelhugger
« Reply #237 on: May 13, 2004, 07:27:59 pm »
Nickle stipple.
(Am I the only one who wants to laugh writing that word? Guess I need to grow up.)
AmericanDemon
« Reply #238 on: May 13, 2004, 07:56:46 pm »
I like it best with the stipple in Nickel plate finish.
Yup, definitely chuckle everytime I write stipple.  There we go again.   ;D
Calawala
« Reply #239 on: May 13, 2004, 07:57:38 pm »
Oooo ... look at those stipples!!  ::)
Seriously though, I like the stipples better (at least in simulation).  Helps define the artwork imo.
