Author Topic: Need a little input on a couple decisions  (Read 1150 times)
crashwg
« on: May 10, 2004, 01:57:04 pm »
OK, so I'm building a MINI-GALAGA, it's comming along fairly well albeit quite slowly... and I've come to a couple things I'm just not too sure on.
My control panel will flip down for access to wiring and such.  See attached pics for how I plan to accomplish this.
My first problem is that I need to round-over the edge of the cp to avoid the red line in my arms from resting them on the cp and also because I plan on wrapping the CPO around the curve and a bit down the front of the machine.  I guess that's not exactly the problem, but this is...  The angle on the board I need to round-over is less/more than 90
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
crashwg
Re:Need a little input on a couple decisions
« Reply #1 on: May 10, 2004, 02:00:38 pm »
And as for how the cp will be flipping...
Lemme say it again
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #2 on: May 10, 2004, 02:21:09 pm »
My suggestion (You'll need a round off bit and a flush trim bit for your router)
The round off bit should have a smaller curve radius than the thickness of your CP.
« Last Edit: May 10, 2004, 02:22:10 pm by abrannan »
If no one feeds the trolls, we're just going to keep eating your goats.
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
« Reply #3 on: May 10, 2004, 02:49:15 pm »
You could always just go nuts with an electric sander and/or grinder.
NoBonus
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #4 on: May 10, 2004, 05:21:27 pm »
The only other alternative I can think of is to finish it with some 1/2 or 1/4 round molding.  While the molding would stick out slightly from the CP it would look just fine as long as the overhang was not too large.
As for the rubbing, I recommend carefully sanding both sides of the CP down a bit so you have about 1/32" gap before painting on each side.  Once you paint it it will seal part of the gap up.
