Author Topic: best way to cut one centimeter down in the control panel for..  (Read 1632 times)
walls83
  • beer is good
my trackball plate?  Is the router the best thing?
Tailgunner
Re:best way to cut one centimeter down in the control panel for..
« Reply #1 on: May 08, 2004, 10:26:05 pm »
Yep, a router would be my first choice.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: May 09, 2004, 06:58:32 am »
Just adjust the router depth and test it on some scrap until you get the depth just the way you want it.
SirPeale
  • Green Mountain Man
« Reply #3 on: May 09, 2004, 09:12:48 am »
Yes, test on the scrap, but you can get the depth you want the first time .
This assumes the use of a plunge router, as I've never used a fixed base one.
Set the material you want to route out for on a flat surface.  Set the base of the router on the material, with the blade off the edge slightly.
Lower the blade until it's touching the flat surface, and lock the router down.  Viola!  Instantly set!
Not my idea, but Oscar's.
crashwg
« Reply #4 on: May 09, 2004, 06:55:05 pm »
As I am proabably going to be doing this soon also, I too have a question.
How do you get the shape of the cuttout correct?  I'm picturing a square box that you'd have to place on the piece you're working on for the router to use as a guide.  Also, the corners... would you have to use a chisel or something?  Routers aren't exactly good at 90
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Chris
    • Chris's MAME Cabinet
« Reply #5 on: May 10, 2004, 11:01:45 am »
--Chris
