Author Topic: Happ trackball feels loose  (Read 2095 times)
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« on: May 08, 2004, 06:11:17 pm »
After about 6 months, my 3" Happ trackball now feels "loose".  Does anyone have any suggestions on how to adjust or clean the trackball for smooth/quick side to side and up/down movement?
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
Re:Happ trackball feels loose
« Reply #1 on: May 08, 2004, 06:56:43 pm »
i too have a similar problem
Apollo
    • Eight Bells
« Reply #2 on: May 09, 2004, 03:02:09 am »
It's probably nothing to do with dirt, how often do you use your trackball? I can't imagine that you have worn the rollers down but I guess if you were on it 5 hours a day for 6 months, that might do it.
Send an email to Happ if you dont get an answer on here.
Xiaou2
  • Last login:Yesterday at 10:15:39 pm
  • NOM NOM NOM
« Reply #3 on: May 09, 2004, 06:28:42 am »
it might just be the rollers have dust/dirt  built up on them...
 but its possible that the new happs 3" trackballs arnt made with the same plastics as they used to be.  Maybe the balls themselves are wearing down - thus the smaller diameter makes them 'hop'  off the rollers.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #4 on: May 09, 2004, 06:43:03 pm »
Mine did this.  You just need to lubricate the rollers with some 3 in 1 Oil, and that will do the trick.
Scoobie
« Reply #5 on: May 10, 2004, 10:39:43 am »
What is 3 in 1 Oil?  Is it WD-40?
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #6 on: May 10, 2004, 10:42:13 am »
It's a light lubricating oil - but not as light as WD-40.  Any hardware store in the US should have it, I would think.
Scoobie
« Reply #7 on: May 10, 2004, 11:08:59 am »
Sounds good.  Does anyone know if the oil will do any long-term damage to the trackball?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #8 on: May 10, 2004, 11:20:04 am »
Heck no; 3-in-1 oil is good.  In fact, don't even consider using WD-40 on a trackball.  It'll gum up the bearings.
Scoobie
« Reply #9 on: May 10, 2004, 12:39:51 pm »
I'll give it a try.  Thanks!
RacerX
« Reply #10 on: May 10, 2004, 02:02:25 pm »
BTW, I meant to say lube the bearings in my earlier post.  You don't want to put oil on the rollers because that will get your trackball all oily.   :P
