Author Topic: Materials Needed to Connect ActLabs Gun to Mame Cabinet  (Read 1116 times)
tw661
  • Last login:July 23, 2004, 11:42:39 pm
« on: May 08, 2004, 10:42:56 am »
I'm thinking about gettin an Act Labs USB light gun.  And was wondering what was the best way to connect it to my cabinet.  I'm taling the hole size and what materials I need to make it look like it belongs there.  Like gromets (i think that's what they are called)  And maybe a gun holster.  And if possible where to get these things.
Thanks for all your help again.
tw661
Re:Materials Needed to Connect ActLabs Gun to Mame Cabinet
« Reply #1 on: May 08, 2004, 07:43:03 pm »
bump
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #2 on: May 08, 2004, 10:52:21 pm »
Well,
  The big challenge is that the guns are wired directly to an interface box which must plug into your computer and monitor cable.  This means that they you really can't insert the cable through a hole in your cabinet unless you cut and splice the wires back together.  You need an opening large enough to move the gun (or at least the box) through.
  In my case, I put them on the oversize keyboard tray behind the keyboard and then pull them out when I need them.  I have a flip down door that covers the keyboard when not in use.
  Another popular option is to mount them (drill a hole near a seam or door in the cabinet so you can actually get the gun through) and put them in holsters on the side.  You can either find appropriately sized toy holsters or buy a real holster.  You can also make them from any flexible material like leather or plastic.
   Some people also use plastic "wire keepers" (kind of like the flexible tube you might have on your vacuum cleaner, but smaller diameter) over the wires to keep them from wearing on the ground and getting tangled.
