Author Topic: Arcade Cab - Inbuilt speakers or PC Speakers...  (Read 1851 times)
timsatari
  • Last login:August 31, 2020, 05:52:07 am
  • By the power of Greyskull!
« on: May 07, 2004, 11:22:21 pm »
Hi all
Would like to get some feedback on the sound for your cabs - what's generally preferred - built in speakers via jamma or pc speakers inside your cab... As Jamma is mono only (I think..) would it be better to mount pc speakers inside your cab? Would this be more versatile for other pc applications as well anyway...
thanks!
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:Arcade Cab - Inbuilt speakers or PC Speakers...
« Reply #1 on: May 07, 2004, 11:32:40 pm »
The speakers on the Jamma Cab are not the best.  However they are made for the machine.  You can go mono in mame and use the speaker ya with an amplifer or hacked speakers to the original.  If you place PC speakers inside you might get too much bass and rattle.  You can always hack a set of PC speakers to connect to the jamma ones to stereo which is probably a nice option.
microwrx
  • Last login:July 06, 2008, 09:22:02 am
« Reply #2 on: May 08, 2004, 02:32:06 am »
My Jamma Cab has 2 speakers.  Don't know if it's stereo or not but there's volume controls for each one.  Anyway, I bought a cheap set of PC speakers and ripped the actual speakers out.  I wired the speaker box (basically just the amp) to the same type of Molex connector my cab speaker wiring uses and that way I can use the cab speakers from my PC in stereo for MAME or plug them back into the cab wiring for JAMMA games.
Witchboard
« Reply #3 on: May 08, 2004, 11:35:46 am »
This may be a little off topic but is still related.. some what.  Has anybody just used their TV speakers for their cab?
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #4 on: May 08, 2004, 11:40:26 am »
I thought about it, but I wanted speakers with a bit more "punch" so I used a set of Creative PC speakers.  The plus side of using TV speakers is that you wouldn't have to wire up a remote volume knob - you could just use your TV remote.  The only thing that might kill it for you is that the speakers might sound muddled once they're behind plexi though.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #5 on: May 08, 2004, 12:22:39 pm »
I went the same route as many others.
I picked up a pair of PC speakers, ripped them open and got the amplifier/volume control board out.
I mounted this inside my control panel with other on/off etc controls. My cp has a piano hinge so its easy to open. Wired these to shielded speakers I got from Happ Controls with all my other goodies.
I have no complaints. Sound is great. I came back later and configured a Jukebox on mine and am still pleased with the resulting stereo sound.
