Author Topic: Monitor Bezel suggestions?  (Read 1409 times)
jeepnut24
  • Last login:May 07, 2004, 08:53:44 pm
« on: May 06, 2004, 07:51:03 pm »
My monitor is 20" and was looking for suggestions on a bezel. Id prefer not to use paper. Any suggestions or picts or examples?
Lilwolf
Re:Monitor Bezel suggestions?
« Reply #1 on: May 07, 2004, 03:53:51 pm »
search on www.therealbobroberts.com
I've seen some small bezels there cheap.
Happs I hear doesnt' charge that much for the smaller bezels (the 27" is about 18bucks...and 50 for shipping :(
but the paper version, and use the slightly expensive poster board and I bet it would look nice... put some smoked glass over it... and your good to go
Tailgunner
« Reply #2 on: May 07, 2004, 06:24:02 pm »
Since it's 20" I'm guessing your monitor isn't an arcade monitor. If this is true, the Happs plastic bezel isn't going to fit properly. You might be able to trim one to fit though.
Other options would be my 2$ bezel
jeepnut24
« Reply #3 on: May 07, 2004, 09:06:35 pm »
Thanks, I may go with a piece of 1/8" plywood sanded smooth with a couple layers of paint to smooth it out. Then plexi or glass on top.
THanks
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #4 on: May 09, 2004, 01:27:57 am »
I have 2 good suggestions for you.
1. Take a peice of thin plywood and cut out in the middle where you screen is, then keep doing about 3 layers of this, each about a hlf inch in to give a 3d efect to your display, just screw or glue the peices together, goup, sand, and paint a few coats of black.
2. Take a peice of plexi glass, and on the back side put masking tap around the area the monitor will be, and spray paint the rest glossy black, when you put it on, all will be black except ypur monitor area.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
