Author Topic: Ball top T-Stick Plus matches with what other 8/way?  (Read 1117 times)
Witchboard
« on: May 06, 2004, 03:45:02 pm »
I'm brainstorming again and was wondering if anyone has mixed their T-Stick Pluses with another type of 8 way ball top.  Which one was it and did you have to do anything to make them match in height, ect.  Thanks.  ;D
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
Re:Ball top T-Stick Plus matches with what other 8/way?
« Reply #1 on: May 06, 2004, 03:51:16 pm »
My suggestion is...don't mix and match unless you absolutely hate the T-Stick for 8 way gaming.  Get two balltop T-Sticks (expensive proposition I know) and be done with it.
My cocktail has a 20th anniversary Ms. Pacman 4-way balltop on one side and I bought the T-Stick for the other side (so I could partake in some vertical schmup goodness).  The 20th anniversary stick is like 1/2 the size of the T-stick, both in height and in balltop size.  I will probably have to break down and get another T-Stick for the 2nd Player side just so the cabinet doesn't look too cobbled together.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #2 on: May 06, 2004, 07:18:48 pm »
Today i just replaced the standard oval handles of 2 T-Stick Pluses with Ultimarc's' short red ball top replacement handles. They now pretty much match in colour and height as the standard handles of Ultimarc's J-Sticks 8way joysticks. There is a very slight difference in color (the J-Sticks are a slightly darker red) but it is very slight. There is a difference in size between the black dust washer things - but that i can live with that.
However, I'm not sure of the height of the standard T-Stick ball tops so might not be same as the replacement handles i have used. suggest you email andy@ultimarc.com and ask him how they compare to the J-Stick. I have found that he is very helpful.
It's a shame the T-Stick Pluses are not available as standard with a ball top handle. Also I would like the T-Sticks Plus to have the same degree of travel as the J-Sticks - but then that is just my preference!
hope this helps!
« Last Edit: May 06, 2004, 07:28:54 pm by rchadd »
Witchboard
« Reply #3 on: May 07, 2004, 12:27:24 am »
I was just brainstorming on another CP I was thinking about.  More geared toward classics.  I was wanting a T-Stick Plus So I could use it for PacMan and the like, but I also wanted two 8 ways for games like Robotron and othesr that are similar.  It just kills me to pay $25 for a joystick, but then pay another $15 just for the ball top.  That's why I was wondering if there were any other joysticks that worked well that already had ball tops and would save me the $25.  Thanks for the input guys.
