Author Topic: Tempest 2000  (Read 1407 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Tempest 2000
« on: May 05, 2004, 09:33:07 pm »
Anyone playing the PC version of Tempest 2000 on their cab? Is it any good?
any problems with playing on a cab with std res monitor?
cheers
« Last Edit: May 05, 2004, 09:34:32 pm by rchadd »
Malachai
  • Last login:April 05, 2014, 11:07:00 pm
Re:Tempest 2000
« Reply #1 on: May 07, 2004, 04:24:28 pm »
I love that game!  There are a few issues I ran into.  Maybe they will save you some time.
1.)  I have to run the DOS version to keep it from running in a window (DOS and WIN95 versions came on the CD), so I had to setup the DOS sound drivers.  After all the soundtrack is one to the best parts of this game.  ;)
2.)  I can't use my spinner with it.  I have to play with the joystick, but it's still a lot of fun.
3.)  There are also parts of the game's menu that you need a mouse to navigate.  I think this can be changed in the settings somewhere, but I haven't found it yet, too busy playing! This isn't really an issue if you have a trackball in your cab.
As for the STD Res monitor...I don't know.  I use a TV.  The game is low resolution though, remember it's made to be a DOS game, so I couldn't imagine you having any problems.
CGRemakes
  • Last login:December 14, 2008, 12:52:09 pm
  • Free Frogger clone! (click on my sig)
    • Classic Game Remakes
Re:Tempest 2000
« Reply #2 on: May 07, 2004, 05:32:17 pm »
Not to jump off topic, but another version that's pretty good (and free) is found here:
http://www.ainc.de/
It's only 96k (music is separate, but small), but has very good gameplay.  Just figured I'd post in case anyone wanted to try it.  :)  It's called Tsunami 2010.
« Last Edit: May 07, 2004, 05:33:05 pm by CGRemakes »
rchadd
  • Made in Cornwall
Re:Tempest 2000
« Reply #3 on: May 07, 2004, 05:54:16 pm »
wow thanks thats awesome - i need to get a spinner!
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
Re:Tempest 2000
« Reply #4 on: May 07, 2004, 09:08:58 pm »
The PC version is okay, it works with the Wingman Warrior joystick/spinner if I remember correctly. I think the Atari Jaguar version is much better, and you can use a real arcade spinner with it (some hacking required).
"Three warps to the Bugger homeworld"
