Author Topic: Ultimarc Trackball / mounting question..  (Read 1109 times)
timsatari
  • Last login:August 31, 2020, 05:52:07 am
  • By the power of Greyskull!
« on: April 29, 2004, 07:25:01 am »
Hi all
I've got my cabinet in business now - now all I need to do is add some buttons and install the trackball. I've got a metal control panel and I was just wondering if anyone has some clean shots of how they mounted their trackball to the control panel - should I have got the mounting bracket? Many thanks all!
tim.
Zakk
  • Last login:Today at 03:14:35 pm
Re:Ultimarc Trackball / mounting question..
« Reply #1 on: April 29, 2004, 10:12:40 am »
I've mounted two of them so far, both into wood, but I used a custom metal mount, basically you just need to find your center, cut the hole (I removed the ball and used the hole in the housing for a template, then just cut the hole a little larger.  Once the hole is cut, mark your mounting holes and drill them.  It's also easy if you have a 2 1/4" hole saw, but I didn't get one because I didn't know if I'd keep using the ultimarc ball or go back to the happ.  Hope this helps a bit, ask away if you have more questions!
http://www.mameworld.net/massive/Cabinet/Cabin/Cabin.html
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #2 on: April 29, 2004, 11:21:43 am »
You're going to have a tough time mounting it in a metal panel unless you have a 2.25" metal hole punch.  Getting the hole in the metal exactly round for the lip of the is going to be pretty tough.
paigeoliver
  • Awesome face!
« Reply #3 on: April 29, 2004, 12:48:58 pm »
I have managed to cut some pretty exact holes in metal using a holesaw and a hand drill. You could probably get it perfect with a drill press.
timsatari
« Reply #4 on: April 29, 2004, 10:00:34 pm »
I've decided to take my control panel to a metal worker / engineer to punch holes for my extra buttons and trackball. It will probably cost $40-50, but cheaper than the equipment that I'll only use probably once!
