Author Topic: Colecovision in Mekaw  (Read 1267 times)
killbill
  • Last login:November 05, 2025, 02:53:17 pm
  • When I die, I want to go to arcade heaven!
« on: April 21, 2004, 05:36:06 pm »
Hi,
I'm running both Sega Master System and Colecovision through Mekaw.
I configured the controls for p1 and p2 in Mekaw.  The controls work perfectly for Sega Master system games, but in Colecovision the p2 controls don't work.
Anyone else run into this?
« Last Edit: April 21, 2004, 05:36:46 pm by killbill »
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
Re:Colecovision in Mekaw
« Reply #1 on: April 21, 2004, 10:04:44 pm »
I have not tried colecovision in mekaw but i do use mess for coleco and feel that it works pretty well. (both controls) I do use mekaw for sega and its seem to work well for that. I will try coleco in mekaw and see if I can get player 2 to work. Anyone know any advantages or disadvantages between mess and mekaw for coleco?
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
killbill
« Reply #2 on: April 22, 2004, 02:14:58 pm »
Hey btodd,
Is the version of MESS you are using mapped to exit with the ESC key?
btoddkelley
« Reply #3 on: April 22, 2004, 07:31:08 pm »
yep. Its just the regular command line version with the new gui turned off.
Todd
- Descartes
