Author Topic: Painting Plexi  (Read 2609 times)
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
Painting Plexi
« on: April 21, 2004, 09:21:45 am »
I'm getting ready to paint a silver bezel on some clear plexi and I just need a little advice from someone who may have painted plexi before.  Do I need to sand the part I'm going to paint?  Also what kind of paint will work on plexi?
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
Re:Painting Plexi
« Reply #1 on: April 21, 2004, 09:25:18 am »
Paint the inside of the cabinet side of the plexi and just make sure it's free of dust or greese. Also when painting just "dust" the surface the first time and then build up in a couple of coats. You are using clear plexi, right?
Mr. Dude
  • Hi...
Re:Painting Plexi
« Reply #2 on: April 21, 2004, 09:59:17 am »
Yep, I'm using clear
Mr. Dude
  • Hi...
Re:Painting Plexi
« Reply #3 on: April 21, 2004, 12:29:32 pm »
Should I sand that part of the plexi though?  And can I use just enamel spray paint or do I need a special plastic kind of paint?
Zakk
  • Last login:Yesterday at 07:55:02 pm
Re:Painting Plexi
« Reply #4 on: April 21, 2004, 01:16:49 pm »
don't sand.  And make sure you get ALL the oil smudges and fingerprints off before you spray or it will leave an unpaintable spot.
paigeoliver
  • Awesome face!
Re:Painting Plexi
« Reply #5 on: April 21, 2004, 03:29:57 pm »
Do not sand, do not sand do not sand.
Now, second piece of the advice.
Use glass, use glass, use glass. I paints better, doesn't scratch as easily, and comes out with a MUCH better finish once painted. And if you mess up, then you can remove the excess paint with a razor blade.
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
Re:Painting Plexi
« Reply #6 on: April 21, 2004, 04:45:03 pm »
use Krylon fusion paint.  It is designed for plastic.
http://www.dickblick.com/zz014/11/products.asp?param=0&ig_id=6372
Your screen name has been added to my frag list.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re:Painting Plexi
« Reply #7 on: April 21, 2004, 06:22:49 pm »
see this test of Plastikote vinyl dye - looks like pretty good stuff...
http://linear1.org/mods/vdye.php
maybe it could be used
Gideon
  • Last login:January 15, 2026, 04:48:25 am
Re:Painting Plexi
« Reply #8 on: April 21, 2004, 09:20:10 pm »
Hmm... If you're recommending something that isn't considered authentic, I'd bet that the reason is pretty important.  Thanks for the advice.
paigeoliver
  • Awesome face!
Re:Painting Plexi
« Reply #9 on: April 21, 2004, 09:34:51 pm »
Actually, glass is authentic, many quality cabinets shipped with glass rather than plexi.
Gideon
Re:Painting Plexi
« Reply #10 on: April 21, 2004, 09:41:38 pm »
Huh?  But it breaks!  That's a little surprising; I don't think I've even seen a cab with glass.
paigeoliver
  • Awesome face!
Re:Painting Plexi
« Reply #11 on: April 21, 2004, 09:44:23 pm »
A large percentage of Atari games have glass (Kangaroo, Centipede, most vectors, and all variants of the standard Atari upright). Many Midway and Williams games have glass as well.
Gideon
Re:Painting Plexi
« Reply #12 on: April 21, 2004, 09:50:09 pm »
Nevermind, then.  I'll catch you recommending something inauthentic some other day...
Rocky
  • Last login:December 30, 2009, 12:38:41 pm
  • I want to finish my cab before I retire!!
Re:Painting Plexi
« Reply #13 on: April 22, 2004, 09:21:44 am »
Gideon,
You are just plain wrong on this one.  Most of the arcade cabinets I have use glass over the monitor (Q*bert, Moon Patrol, Klax).
Also, just as a tip, paigeoliver is one of the most knowledgeable guys when it comes to arcade games, cabinets, equipment, etc.
Plexiglass and glass were both widely used.  Glass is more old school, I think.
Rocky
Zakk
Re:Painting Plexi
« Reply #14 on: April 22, 2004, 09:55:57 am »
Paigeoliver is quite correct, a LOT of cabinets came with glass, since plexi for a bezel could be vandalized quite easily  (an operator would hear someone breaking glass, but wouldn't hear someone scratching their high score forever into the plexi).However, a lot of glass bezels have indeed been broken over the years, and it's a lot easier to cut a piece of plexi than cut a piece of glass (plus they would keep sheets of plexi hanging around for just such an occasion).  Glass is MUCH better to work with paint wise, but plexi will work fine, just get it right the first time since that paint won't ever be coming off.
And I second the fact that he knows what he's talking about :)
paigeoliver
  • Awesome face!
Re:Painting Plexi
« Reply #15 on: April 22, 2004, 01:52:07 pm »
Glass isn't too bad. Just have the place cut it for you. I have even ordered smoked tempered glass in the past for some machines, and it was never too pricey.
Shouldn't be much more than $10 for standard glass, smoked tempered will probably be closer to $30.
