Author Topic: MAMEWAH AND SEGA CD  (Read 1293 times)
dskillz1
  • Last login:January 23, 2020, 03:04:13 pm
MAMEWAH AND SEGA CD
« on: April 16, 2004, 05:32:08 pm »
Hello all!
I just got MAMEWAH to work with the GENS Emulator 2.11 for Sega CD games.  Everything works fine except the needed MP3 files for sound never play, so I basically never have backround music.  I know mamewah is the problem because when I use Gens seperatley everything is fine, I hear all the music that should be there.  I have my Iso and mp3 files all named correctly with the corect naming convention.  Has anyone had the same issues?  If so how can I get around it?  Maybe a batch file or some other workaround?  Any help would be great, thanks in advance!
Darryl
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
Re:MAMEWAH AND SEGA CD
« Reply #1 on: April 18, 2004, 09:48:23 am »
Try Sending long filenames to Gens.
Depending on how you have named your files, If the filenames are over 8 char's the command that MAMEWAH sends and the name of the MP3's don't match so Gens will not play the MP3 files. It took me a while to figure this out but i got there in the end ;D
Hope this helps.
