February 11, 2026, 06:19:45 pm
Exactly Jm... I can tell you the ones that are coded properly. (To my knowledge at least)MineArcadeFxEmuwizardGamelauncherAos seems to have a problem with it as does a few of the other dos fe's. Mame 32 isn't coded properly either, but that's to be expected as it's intended to be used in a normal windows environment and not on a mamecab.
hey...mine works also ok...yeah there is still a gamelist menu in it besides the arcade..in fact I optimized it a lot for next release ;-)
JFront also works with this.as an frontend programmer... when testing on your own cabinet... you catch this right away.If your writing one for a computer... you wouldn't think about it since the standard keyboard encoder does this for you (where arcade ones do not)
Yep, exactly why on mine (not available to public, but it might) categorizes by categories, has a search, and has favorites. All navigatable with the joystick, a select button, and a page up and page down button.
