Author Topic: "Neat" Control Panel idea  (Read 2129 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: April 12, 2004, 06:40:09 pm »
Guys you should definately check out this guys site
http://mywebpages.comcast.net/jdpyle1/controls.htm
he does the control panel beautifully I never thought to use barrier strips and spade plugs, virtually no soldering necessary. No mess no fuss
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
Re:"Neat" Control Panel idea
« Reply #1 on: April 12, 2004, 06:53:37 pm »
Nice use of the barrier block!  That is definately how I am going to go with mine.
NoBonus
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #2 on: April 12, 2004, 07:04:55 pm »
I was thinking about doing that myself too. In fact I already bought the strips for it. But looking at this example it seems a bit messy.
BTW, with the strips I have, I wasn't intending on using "spade plugs". I would just screw in a blank end of wire on both ends.
AND I was planning on putting it at the back edge (where the connector is) so it wouldn't get in the way of the controls that will be in the middle of the CP.
« Last Edit: April 12, 2004, 07:08:19 pm by patrickl »
NoBonus
« Reply #3 on: April 12, 2004, 07:23:58 pm »
Where does one get barrier blocks? RadioShack?
Gideon
  • Last login:January 15, 2026, 04:48:25 am
« Reply #4 on: April 12, 2004, 07:26:33 pm »
Yeah.  I believe they're called "European style terminal strips."
NoBonus
« Reply #5 on: April 12, 2004, 07:30:13 pm »
Ahh, those clever Europeans and their terminal strips...
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #6 on: April 12, 2004, 07:37:51 pm »
In dutch these are called "kroonsteentjes" (I guess that would translate to "crownblocks" ) I'm not sure he's using the same thing though, since they are supposed to be used without any additional connectors (i.e. just put in a bit of blank wire and fix it with the screw)
I just checked the Radio Shack website and european terminal strips is the stuff I have. I just wonder if Radio Shack makes these things from solid gold, seeing how much they charge you for them!
« Last Edit: April 12, 2004, 07:43:42 pm by patrickl »
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #7 on: April 12, 2004, 08:43:51 pm »
cdbrown
  • Last login:October 16, 2017, 09:52:03 pm
  • Bowowow
« Reply #8 on: April 12, 2004, 11:15:41 pm »
I also went for the barrier strip or terminal strip.  I didn't want to do any soldering and wanted to be able to easily fix any wiring problems (ie not connected properly).  I was also connecting to DB25 cables and figured the strips would be the easiest method.
NoBonus
« Reply #9 on: April 12, 2004, 11:47:34 pm »
Is it just me, or do the European style terminal strips seem like something that could be easily constructed at home using a piece of wood, some screws, and some little bits of metal?  All you would need would be a drill, a wood carving tool of some sort (saw, dremel, drill, knife) and a tin snip to do it.
NoBonus
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #10 on: April 13, 2004, 04:04:08 am »
Well you could make em yourself but I spent 3 euro (about $4) on 6 12 terminals strips. I guess it wouldn't even be that easy to make em yourself.
A barrier strip would probably be even easier to construct yourself. Basically a strip of wood and some screws. I'd use one screw to tie down 2 spade connectors, but then, for the cost of the spade connectors you should be able to purchase the terminal strips  ...  ::) So you could tie down bare wire, but you better make sure the barriers (between the terminals) are in place  :P
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
« Reply #11 on: April 13, 2004, 06:30:13 am »
Only down side to using terminal strips is it adds 2 (4 if you use terminals) more potential places for a circuit to break.
  • Last login:Yesterday at 04:39:53 pm
« Reply #12 on: April 13, 2004, 07:25:03 am »
I used barrier strips as well as spade plugs in my last stand alone controller.  I tell you, it makes life a heck of a lot easier.
Plus, it looks neat.  :)
My controller:
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=17483
