Author Topic: connector type - see pics  (Read 970 times)
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« on: April 05, 2004, 10:27:36 am »
Hello all,
  I'm looking to extend the firewire port in my PC out to my CP. I attempted to extend the wire by splicing 8 wires into the middle, but my confidence isn't too high that it's going to work. :)
  I was in the shower this morning (I seem to do all my best thinking in there *shrug*) and it occured to me that it would probably be simpler if I simply wire in an 'extender cable' by attaching one end the the end of the existing cable and attaching the other end to the recepticle on the motherboard.
  I did some searching on the internet for anything that looked close to the type of connector, and the closest I came up with was a SPOX connector. Do any of you know off the top of your head if this is accurate?
Thanks for your help!
/Steve
« Last Edit: April 05, 2004, 10:30:35 am by screaming »
fredster
  • It's all good!
Re:connector type - see pics
« Reply #1 on: April 05, 2004, 11:10:56 am »
looks like .156 pins.  Ask Bob Roberts, he has similar connectors. You don't need all the interlocks, just the spacing to make it right.
