Author Topic: J-ROC? what is it? where?  (Read 1631 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: April 05, 2004, 03:55:23 am »
Someone recommended an interface called J-ROC? where can i get it what does it exactly do?
thanks
JIM
PS-I checkd google negative results
eb
  • Last login:August 30, 2006, 11:06:36 pm
Re:J-ROC? what is it? where?
« Reply #1 on: April 05, 2004, 04:53:55 am »
What sort of interface? He didn't mean J-PAC did he?
Sometimes you have to sit down for what you stand up for
Demon-Seed
« Reply #2 on: April 05, 2004, 09:18:17 am »
Not sure.. I found jrok.com it sells arcade parts etc but not the interface this guy was talking about. it was an interface to hook up multi consoles i think
Goz
  • KOTA
« Reply #3 on: April 05, 2004, 09:47:59 am »
JROK's are used to convert RGB to Composite or SVIDEO signals.
Here's their product info
http://www.jrok.com/hardware/RGB.html
Edit: Added
What does it do ?
This unit will convert the Red, Green and Blue video signals coming out of a video game and convert it into the composite NTSC video, or S-Video, output.
It allows you to plug a Video arcade game board into a regular TV receiver that accepts video, or S-Video input, in the NTSC encoding format.
This board ONLY works with standard resolution arcade boardsets ( 15kHz horizontal line frequency )
Hope this helps,
-Goz
« Last Edit: April 05, 2004, 09:56:21 am by Gozur »
Demon-Seed
« Reply #4 on: April 05, 2004, 10:47:04 am »
Hey
yea that makes sense. I have no idea why he suggested me to use that too connect multiple consoles together? I guess he thought I was using an arcade vga screen
thanks for the hlp
Lilwolf
« Reply #5 on: April 05, 2004, 11:47:41 am »
I would rather see something going the other way...
but that is what a ArcadeVGA is for... but I do love my 9700... but I guess I don't have a use for it on an arcade monitor.  I would love to see some game running at 8xAA at low resolutions..
JoeB
  • Last login:January 28, 2026, 10:28:49 pm
  • NES Fanatic
« Reply #6 on: April 05, 2004, 04:21:11 pm »
J-ROC is commonly used by people that build superguns.
It allows you to connect any PCB/JAMMA board directly to your TV.
microwrx
  • Last login:July 06, 2008, 09:22:02 am
« Reply #7 on: April 05, 2004, 08:19:05 pm »
I have a converter that converts a composite signal to RGB.  I'm using it on a 50" rear projection monitor from a Konami Krypt Killer machine to use as a TV.  The picture isn't as good as a regular TV but running a digital set tob box to it makes it more than satisfactory for a cheap big screen TV.
