I decided that I hate my Astropad so it's my pick for hacking. This would be my first controller hack so I'm a little green. I've read several tutorials that were linked to from here but need a little bit more assistance.
The Astropad looks pretty simple inside. There's a daughter-card for the d-pad that has the switch contacts on it. Five leads come from the daughter card and attach to the main board (L, R, U, D, and gnd). I'm assuming I can just cut the daughter card off and solder directly to the wires.
A, B, X, Y is set up the same way. I want to cut the wires and connect leads from my microswitches directly to those wires instead of soldering to the daughter-board copper switch contacts or using the mainboard connection points. Seems easier and less risky to do the soldering off the board.
The two shoulder switches are wierd analog 3-wire switches. I found a thread on this board from fall 2002 that indicates how to wire those switches:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=3511;start=msg21723#msg21723The start button has two red wires coming from it and they disappear under the board (which will be difficult to remove so I think I'll leave it in place).
My questions:
1) How can I validate the wires that I think are grounds really are? I own a multimeter, but don't know how to use it for this application. Is there a procedure I can follow to validate all of my wiring choices?
2) Should I validate that the grounds for both daughtercards are the same? How do I do that? My CP is currently all daisy-chained together for ground. I assume that I'll be connecting that daisy-chain to the ground circuit of the DC controller. I'm not sure what the implications of dual grounds are.
3) I assume that one of the two start button wires is a ground.
So this looks pretty easy excepting the wierdness of the shoulder switches. Cut three sets of wires and solder them to the correct leads on the CP.
Anything to worry about? I assume I can blow the controller ports by mixing up grounds, but otherwise, is there any other danger or anything to be concerned with?
Thanks folks! I'll post a pic of the final wiring if I'm successful with this. I won't, of course, if I get scared and bail on this...
 -pmc
