February 28, 2026, 07:27:35 pm
A good way to check if you have the correct height is to round the slot on one side of a scrap piece of wood and then turn it over and make sure that the cutter fits exactly into the slot. If not adjust and try again.
People that use laminate, do you apply laminate first and then cut your t-molding slot or do you cut your t-molding slot first and try to adjust for the thickness of the t-molding? I can think of pros and cons of doing it both ways.
