Author Topic: To smoke or not to smoke?  (Read 1894 times)
jedimason
  • Last login:May 16, 2007, 08:33:54 pm
  • I've just sucked one year of your life away.
« on: March 31, 2004, 06:58:41 pm »
I'm building a cocktail table and can't decide whether to have clear or smoked glass.  What do you guys think?  What looks best for a cocktail cabinet?  Pro's and con's?
Thanks for the help.
-Jedimason
OSCAR
    • Oscar Controls
Re:To smoke or not to smoke?
« Reply #1 on: March 31, 2004, 07:03:48 pm »
I have clear tempered glass on my cocktail.  That would probably be best if you are going to have a graphic underlay, the smoked glass will probably mute the colors on the graphic a little.  I have an instruction card under the smoked plexi on my upright, and it is a little difficult to read.
If you aren't planning on a graphic underlay, then I would say go with smoked glass.  It just makes the screen look better, IMO.  If I had it to do over again, I would use smoked glass on my cocktail since I don't have any graphics under the glass.
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #2 on: March 31, 2004, 07:36:25 pm »
I used clear tempered glass.
What I did with mine was,  I routered a small amount away from around the inner wood frame of my top and set a small square piece of smoked plexi glass over the screen.  It came out great and doesn't affect the underlay art at all.
I bascially got a piece of smoked plexi glass that is the size of my screen and set right over the screen.  The routered edge of the inner frame of the cocktail top allows the plexi to sit flush with the top and still be able to set the cocktail glass over it.
Hope that makes sense?  Almost time to go home from work, so I'm a little tired!
« Last Edit: March 31, 2004, 07:37:17 pm by creatine28 »
ButeLegz
  • Last login:December 10, 2003, 06:23:38 pm
  • Feldman knows best.
    • www
« Reply #3 on: April 01, 2004, 01:47:02 am »
That's pretty much what I've done with mine too. Except without access to a router I glued small peices of a clear cd to the underside of the lid to hold the smoked plexi flush. Bummy I know, but effective. It's also pretty much the way it was done originally... on the cocktails I've seen here anyway (Hankin, Taitio...) - the routing that is, not my crunk cd method.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #4 on: April 01, 2004, 10:11:33 am »
I used smoked, it looks great. I don't have an underlay however
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #5 on: April 01, 2004, 10:13:37 am »
Used smoked to hide a slight burn in on a used monitor that I bought.  Works well.
I guess it depends on your needs
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #6 on: April 01, 2004, 09:23:44 pm »
I used smoked, tempered glass on my cocktail as well and you'd be surprised at how little it impedes the view of an overlay..... Mine is a fairly dark tint and the colours are perfectly bright. You can hardly tell it's tinted when looking at the overlay. Maybe small text would be harder to read but mine doesn't seem like it would be.
If you build a frankenpanel, chances are I don't care for you as a person.
