Author Topic: Monitor/Surround/Bezel Installation  (Read 1268 times)
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
« on: March 30, 2004, 10:48:20 am »
Hey gang,
My project has moved onto the all important monitor installation stage. Could someone be kind enough to point me to a link with installation pics showing the proper way to cleanly rail mount a WG monitor, with surround and 1/4" bezel? Sorry to be sort of vague, I'm more or less looking for some examples.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:July 14, 2025, 03:43:29 pm
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:Monitor/Surround/Bezel Installation
« Reply #1 on: March 30, 2004, 11:11:13 am »
If you have a frame (most don't) you can do what I did to mount it:
http://www.mamenation.com/images/IMG_1325.JPG
http://www.mamenation.com/images/IMG_1324.JPG
From what I have seen, most folks without frames use shelves for monitor mounting.
I have a back-painted,  tinted glass/bezel.  It is attached to angle iron with magnetic tape.
http://www.mamenation.com/images/IMG_1478.JPG
Dave
« Last Edit: March 30, 2004, 11:12:57 am by Santoro »
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
« Reply #2 on: March 30, 2004, 01:01:01 pm »
Depends on the type of frame you have.
You can build a frame of 1X2's around it and let the lip of the metal frame rest on that.  You can build a shelf.  I had a cab that had a piece of plywood and the center was cut out to match the monitor.  The monitor was mounted inside that.  Then it had a rail on each side and the plywood rested on that.  Pretty simple.
If you have a frame that has a base on it, just make a shelf.
King of the Flying Monkeys from the Dark Side
