Author Topic: Gens issue  (Read 994 times)
killbill
  • Last login:December 17, 2025, 04:32:58 pm
  • When I die, I want to go to arcade heaven!
Gens issue
« on: March 29, 2004, 01:21:14 pm »
Hi,
I'm having this issue with Gens where it plays fine, but after a little while the screen starts to glitch once every five to ten seconds.  After a couple of minutes it seems to stop, but then starts up again later on.
Hs anyone had this issue?  If so, what can I do to stop it?
Thanks.
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
Re:Gens issue
« Reply #1 on: March 29, 2004, 04:03:10 pm »
If you haven't already you might want to turn on vsync.  I used to have some trouble in Gens before I used vsync.
killbill
Re:Gens issue
« Reply #2 on: March 29, 2004, 04:59:56 pm »
I'll check tonight, but I think I have VSync enabled.
Is there anything that should be changed in the settings if you enable VSync?
Like refresh or frame rate, etc?
Thanks.
Re:Gens issue
« Reply #3 on: March 31, 2004, 05:26:50 am »
You could try some different graphics render settings...
killbill
Re:Gens issue
« Reply #4 on: March 31, 2004, 02:46:44 pm »
Thanks Miniwah.
I'll try those tonight.
