Author Topic: mame prob with older comp  (Read 2113 times)
Truz
  • Last login:February 23, 2009, 12:03:01 pm
« on: March 28, 2004, 07:35:21 pm »
Well i decided to fool around with my old laptop ( a toshiba sattelite 330cds) and see if i could get mame running on it, because maybe sometime down the road i can stick this in a cocktail cab and play ms pac galaga and the like.
So i put windows command line mame (.80) on it and tried to fire up ms pacman but i get this error:
Error getting directdraw capabilities: 80070057
Unable to start video emulation
Anyone know a fix to this problem?
HagHore
  • Last login:October 24, 2007, 02:24:00 pm
  • Game Over Man, Game Over!
Re:mame prob with older comp
« Reply #1 on: March 28, 2004, 07:58:37 pm »
What version of DirectX is on your laptop?  You may need to update it.
We're on an express elevator to Hell! Goin' down!
Truz
« Reply #2 on: March 28, 2004, 08:28:18 pm »
hmm... well it is pretty old its a windows 95, i guess ill just get the latest dircetx that works with win95 (i think its 8.0a) and ill see if that helps.
Truz
« Reply #3 on: March 28, 2004, 09:02:44 pm »
well i updated directx and that did the trick and i got ms pacman up and running.
It took a bit for it to load but once it started up it was running at around 55 fps.
I was surprised at how well it ran, here are the specs of this computer
 Processor
    * Intel Pentium (1.8 volt) with MMX technology, running at 266MHz
    * 512KB pipelined burst SRAM level 2 cache
    * 66MHz bus clock speed
 Memory
    * 32MB EDO DRAM standard
So my question to you guys is, i see some of you running mame on some really old comps, how to you improve your load times of the games. It took a while for the game to load but after that it ran great. So how are the load times for those of you running older systems and what have you done to improve em?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #4 on: March 28, 2004, 10:17:38 pm »
Try using VAntAGE instead.
Truz
« Reply #5 on: March 28, 2004, 10:19:22 pm »
cool, thanks peale, just checked out the Vantage website, seems to be what i am looking for. I'll give it a try.
Anyone else have any tips for older systems.
« Reply #6 on: March 28, 2004, 11:16:07 pm »
Your machine is hosed... you should have known this when you had issues with windows mame (which will run on any pos machine)
reformat, put something other than windows me on it and start from there.
You may not like this advice, but virtually everyone is going to tell you the same, probably because it's the best thing to do.  :)
SirPeale
« Reply #7 on: March 29, 2004, 08:32:16 am »
Or just don't use Windows.  But then you likely don't have DOS sound drivers for that laptop, do you?
Truz
« Reply #8 on: March 29, 2004, 08:46:12 am »
ummm casto, this is a totally different machine than the one from my other topics. This is an old laptop that i have been playing around with that has windows 95 on it. The "hosed" machine you are refering to was an old desktop (p4 1.3ghz) with windows me on it that i was having problems with.
I was playing around with this old laptop to see if maybe it had some potential in the near future so i could maybe stick it in a cocktail cab or something.
mclaught
  • Last login:April 20, 2006, 08:09:11 pm
« Reply #9 on: March 31, 2004, 02:53:01 pm »
find yourself an older version of mame, something in the 35-37range. Works much better on the older computers. Go  to this link http://mame.joymonkey.com/mame32.html to find some versions to mess around with.
« Reply #10 on: March 31, 2004, 03:06:26 pm »
Then why did you mention it in your post?  Unless you want to confuse everyone, don't post info we don't need.  :)
Btw I know you didn't mean anything by it but don't call me "casto".  That is my last name unless you tack a "Mr." on the end of it, it's disrespectful to address me that way.  Howard works just fine.  :)
Truz
« Reply #11 on: March 31, 2004, 04:15:50 pm »
ok Howard i didnt bring up the other machine at all in my orignal post you did, i was just clarifying that that was not the machine i was refering too.
Thanks for the input everyone.
« Last Edit: March 31, 2004, 04:26:24 pm by Truz »
paigeoliver
  • Awesome face!
« Reply #12 on: March 31, 2004, 04:33:22 pm »
Try a Mame version around .53 and use DOS mame, that way you don't have to worry about directX issues or other mess like that.
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: April 01, 2004, 07:17:43 am »
Like he said, he didn't mention it, you did.
And don't call me Casto, any of you Homo's call me Casto and I'll kill you . . . Lighten up, Howard!!!
Just kidding, couldn't resist.
Lilwolf
« Reply #14 on: April 01, 2004, 08:32:11 am »
If speed is an issue... mame version around .36 (one of the betas) is where they changed the bpp default away from 8.  This was a pretty big speed hit.
Remember... on many systems, you can have more then one version of mame and one roms directory (but you probably want to seperate them also).
So find a frontend that handles multiple mame/emulators well, and get a few versions.  Older the faster it will be..
Also, look at other emulators WHENEVER possible.
NeoGeo - bunch of options
CPS2 - again, quite a few
Rygar - REM! is the best for slow computers
Gauntlet - mge does wonders
Vintage - whenever you can
try them all... finding roms for them might be an issue thought...
