Author Topic: motherboard, powersupply and a Monitor!!  (Read 1178 times)
jlampc
  • Last login:February 02, 2022, 07:33:58 am
  • I am not an animal !!! I am a gamer
« on: March 22, 2004, 01:00:07 am »
I need to get your opinion. I am looking for a place to mount my Motherboard and powersupply for my pc. I have an arcade cabinet that has a slanted panel about 12 inches below the arcade monitor chassis. I was thinking of putting it there. I'm not worried about heat I can get some fans or leave the back open. My real issue is will the motherboard cause any interference with the monitor. I  don't want to damage the monitor (29 inch). Can either the powersupply or motherboard cause any em or  electrical interference to the  monitor. the PC will not be housed in a case.
ThanX
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
Re:motherboard, powersupply and a Monitor!!
« Reply #1 on: March 22, 2004, 11:51:00 am »
Check out this link for really good info on positioning of the components.   You probably on't need fans if you do it properly.
A similar arrangement has worked out really nicely for me.  I require no additional cooling and have no interference problems.
Dave
« Last Edit: March 22, 2004, 11:55:23 am by Santoro »
