Author Topic: Advancemame w/ Trident Blade and arcade monitor  (Read 1485 times)
wfg97079
  • Last login:March 24, 2023, 10:11:50 pm
« on: March 20, 2004, 09:30:40 pm »
 Anyone here have this config?
If you do I'd love to run a few things by you
Drop me a line
thanks
uepa
  • Last login:May 06, 2004, 08:38:17 pm
Re:Advancemame w/ Trident Blade and arcade monitor
« Reply #1 on: March 21, 2004, 08:02:01 am »
Ok, ask away.  I am running AdvanceMame with a Trident Blade T64 and a D9200.  It's just awesome!  I suggest you check out desmatics website also.
http://easymamecab.mameworld.net/
wfg97079
« Reply #2 on: March 27, 2004, 08:32:06 am »
anyone here using easy mame cab with a k7200
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« Reply #3 on: March 28, 2004, 07:47:30 pm »
I've got a K7200 with a Trident T64 running AdvanceMAME.  I'm still tweaking it, but I used the DOS versions of ADVMame, Game Launcher, etc.
I copied the advcab files as well.  If you are going the DOS route, get the DOSBLADE tsr and load that in your autoexec.bat.  One that loads, text mode looks beautiful on this screen.  The next step for me was to run ADVCFG and select the Wells Gardner K7200 series monitor.  Then tweak the video modes with ADVV.
For Game Launcher, you have to pick a resolution that is supported and change its .cfg file.  I think it defaults to 640 x 480.
