Author Topic: HELP! Hooking up buttons to jpac - no one has a jpac??  (Read 1303 times)
snowdogg187
  • Last login:June 16, 2008, 12:08:18 am
« on: March 19, 2004, 01:36:19 am »
Hey guys,
Now I need to hook up 6 more buttons to my jpac, any input on this?
I know you hook all the grounds together daisy chained.
but do I just hook each other button to another switch on the jpac?
What connectors should I use, or should I get a soldering iron?
thanks very much!
« Last Edit: March 19, 2004, 07:21:44 pm by snowdogg187 »
krick
  • Gotta have blue hair.
Re:HELP! Hooking up buttons to jpac - no one has a jpac??
« Reply #1 on: March 21, 2004, 03:08:07 am »
On a J-PAC, buttons 1-3 for each player are connected through the JAMMA edge connector.
4-8 for each player are connected to the J-PAC using the screw terminals on the board.  just stick the wire in the hole on the side and tighten the screw.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
snowdogg187
« Reply #2 on: March 23, 2004, 12:44:45 am »
Thanks krick, I just wanted to make sure.
I have the wires but should I use connectors or solder or anything?
thanks!
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #3 on: March 23, 2004, 10:15:24 am »
Connectors man. always connectors:)  just incase a switch goes bad.. it happens
